Specsavers UltraClear SuperClean
1 Jun 2012
UK
Any glasses wearers here get these type of lenses from specsavers?
Got a new prescription 2 weeks ago with this coating, was told would help with glare from monitors and so on, which i thought was great as my day job is IT, spend most of the day looking at a screen. However, pretty much as soon as i got home had to turn the brightness down on both my displays, and if i read anything with a white background legit feels like im staring at the sun. I've turned my monitor brightness all the way down to 5 just to make it bearable.
I've rang specsavers and was told that its nothing to worry about, just cause of the prescription change blah blah, but its been 2 weeks and really no change, was wondering if anyone had got the same type of lense and had a similar experience? I'm pretty certain the prescription is correct, i'd be having headaches otherwise.
If this is just what they call the top level with all the coatings one can get then yes, I have them.
And I don't have the issue you've described.
