Spectre Pro Rubber Mounts
4 Jul 2011
England
How do I use the rubber mounting things that come with the Spectre Pros, I was looking and had no idea how when worked. They didn't seem to fit through the fan screw holes so was baffled. Probably just a simple thing I've missed but though I'd ask as they look better than using screws.
EDIT: Just noticed I was doing it right however the rubber rings on the 600T mean these will not work. Also pretty annoyed that the 200mm Spectre Pro doesn't fit in the top spot of a 600T so now need 2x120mms. Damn cash runs out fast.
