11 Dec 2012 at 23:38 #1 Loxa Loxa Associate Joined 18 Oct 2011 Posts 2,297 Does this bundle arrive preassembled? http://www.overclockers.co.uk/showproduct.php?prodid=BU-141-OE
12 Dec 2012 at 00:04 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,573 The CPU may be fitted, possibly the RAM as well, but you'll likely have to fit the cooler yourself. The larger CPU coolers usually aren't fitted in case any damage is caused in shipping. Post in Customer Service for a definite answer. Last edited: 12 Dec 2012
12 Dec 2012 at 00:11 #3 Loxa Loxa Associate OP Joined 18 Oct 2011 Posts 2,297 Surveyor said: The CPU may be fitted, possibly the RAM as well, but you'll likely have to fit the cooler yourself. The larger CPU coolers usually aren't fitted in case any damage is caused in shipping. Post in Customer Service for a definite answer. Click to expand... Ok thanks
