speed controller for a Molex connector fan?
11 Jul 2007
Southampton
help!
which of the fan convector on OCuk do i buy for converting a Molex connector fan to a FanMate2 speed controller that came with my Zalman CPU cooler?
the FanMate2 controller has 1 3-pin input, and 1 3-pin output.
so i want to power 2 cheap Molex connected fans. which product do i buy from OCuk?
as you know, the fans' molex connector is in parallel with another female output.
so can i wire the 2 fans like this? will it work?
[note, the 3-pin to male/female is the first link provided by mark1]
edit: the Corsair HX 620w don't seem to have a 3-pin fan cable, looks like i'll need to buy 2 3-pin fan to 4-pin molex?
that looks to be much cheaper and simpler.....
thank you very much. i'll use the "7v fan mod" instead.
/close thread pls
