Speed Fan Question
17 Dec 2004
Crawley, WEST SUSSEX
I just wanted to know if there is a way to find out which temperature is being shown in speed fan?
What i mean is that you have like 3-4 temperatures listed, but all they say is temp. I want to know which one is the CPU, HDD etc is there a way to find out where and what these temps that speed fan show actually mean??
Thanks
deduction mate, its not hard.
Use something to load the cpu - SuperPI, prime95...whatever. Whatever one goes up the most is the cpu temp. when you find out which one it is go in to the options and rename it. job done.
The one that goes up the least should be the chipset temp. The one that goes up the least is the ambient temp.
If there are any that dont move at all (like being stuck @ 27c or 127c) you can pretty much garuntee they arent even sensors and you can just turn those readings off.
