27 Oct 2013 at 00:50 #1 Dual Dual Associate Joined 29 Aug 2008 Posts 103 Do you think temp 3 is my CPU? Fan 1 is my coolers fan.
27 Oct 2013 at 01:19 #2 asim18 asim18 Soldato Joined 5 Dec 2006 Posts 15,381 Theres only one way to make sure. Leave PC at idle, check temps, then start a CPU benchmark and see which temp rises. Or you could give coretemp a go: http://www.alcpu.com/CoreTemp/
27 Oct 2013 at 11:27 #3 Dual Dual Associate OP Joined 29 Aug 2008 Posts 103 Gave it ago core temp seems to fluctuate with different temps though. Temp 3 could be the MoBo temp? 70c for 30% cpu usage seems extreme for the CPU. Core temp shows: I'm hoping my CPU is temp 2. Thanks, must be my unusual MoBo Biostar TA970
27 Oct 2013 at 11:38 #4 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,665 Location Spalding, Lincs I would ignore anything speedfan says, awful piece of software.
