Speedfan 4.28
mrk
mrk
Man of Honour
18 Oct 2002
Uranus hehehe
What the heck, did you guys see that? fast :D
</coat>
Anyway...4.28 is out with some new features
4.28 - added IN-DEPTH HARD DISK ONLINE ANALYSIS tool
- added centralized INTERNET configuration tab in CONFIG dialog
- added support for NForce410
- added support for new video cards
- added Temperature Sensor Type, BJT Offset and Gain support for Fintek F75375S in CONFIGURE / ADVANCED (on Asus V9999 you might need to set BJT OFFSET from 174 to 202)
- SMART overall indicators are computed using a more advanced strategy
- updated the help file
- properly fixed byte swapped HDD model names
http://www.almico.com/speedfan.php
Ran the HDD report feature on both my sata drives and got...
Seagate 80GB
http://www.hddstatus.com/hdrepshowreport.php?ReportCode=41305&ReportVerification=272B7298
Maxtor 200GB
http://www.hddstatus.com/hdrepshowreport.php?ReportCode=41310&ReportVerification=9F462DE7
Seems it uses a 3dmark like report scheme, using other peoples averages for comparison along with manufacturers guides.
Thanks, downloaded and installed.
How did you rename those temp sensors?
And it's not looking good for one of my hard drives:
Error: Reallocated Sector Count has reached its threshold. Current value is 63 and threshold is 63.
According to S.M.A.R.T. specifications, your hard disk is failing and needs to be immediately replaced. Backup your data as soon as possible.
:eek:
Any idea how long it's gonna last?
Reallocated Sector Count sounds like a important part of the drive but smart is a guide only, you cant get estimates on how long the drive will last =0 - could be weeks, could be months or even years! good emasure is to backup and replace!
You can rename the sensors by going into config and F2ing the sensors!
