Speedfan gives me 2 CPU temps?
If there is a massive variation then your thermal paste application and/or heat sink might be at fault. I wouldn't worry about a couple of degrees though.
Well, it's two processors on one die, and they can each report their own temperature. On a quad you'll see four. Not sure how many it will scale up to though, as I doubt it would make sense to have 16, 32, 64 temperature readings for such a small space as core counts climb in the future.
