Speedfan - Odd Readings
29 Mar 2007
Swindon UK
I noticed that Speedfan has started returning some very peculiar readings...
It tells me that both my CP and System fans are spinning at 1,350,000 rpm (think the case would have taken off if that was so) and that all fans are running at 100%. Mobo is a new Gigabyte S3, running a Conroe 6600 at stock speed. Not attempted any o/c yet other Easy-Tune temporary increase as for some reason Ctrl-F1 is not letting me loose in the BIOS. However that's an aside, I really want to fix Speedfan - has anyone else had this problem? Would uninstalling then reinstalling the utility fix the problem?
apprently my fan idle speed is 1300 and full speed is 25000rpm. I wasn't aware my fan turned into a small supercharger :p
