SpeedFan problem
12 Nov 2006
London
Well i realy need programm to monitor my Fan speeds, but i am speding hours and hours with speedfan and cant make it work ,i cant change speeds dunno why , so i was thinking is it couse it doesnt support my mobo? Or maybe i disabled something in BIOS when i was overclocking my cpu? :/
hmm i checked everything again, i read manual twice ,i think Probe 2 software which i installed from mobo CD might be the reason why it wont work properly ! i will delete Probe 2 and check it again !
http://img406.imageshack.us/my.php?image=newbitmapimage2hh4.png
doesnt look good ,what is that AUX,there is no such a place in my case where it could get that hot 3x120 Fans 1x80mm fan ,Artic ati silencer for gfx, and AC7 Pro for cpu !
I have the same problem as you. i have no idea what AUX is (runs real hot, maybe NB or SB?)
To control the fans change the values in Speed1 & Speed4. Speed2 is your CPU fan & Speed3 I have no idea
yeah !
i tryed my cpu fan is ignoring all that stuff,so i can only control it from BIOS switch silent mode-optimal-or perfomance :/
Thats funny, you should be able to change CPU fan speed with Q fan disabled.
can you control other fans (case fans)? What cooler are you using?
i got AC7 PRo ,and i found out how to control, but only cpu cooler, not case Fans-it wont let me change thouse speeds! But programm aint be that good,it only works when u start progrram,would be mutch better if it could control it somehow with BIOS ,so when ever u start pc it would use my settings,my cpu Fan speed,but it wont save that way !
thanks for help anyways !
