When using speedfan to adjust fan speeds, i change the speed for instance to 50%, but it doesnt slow the fan down in any way. Fan is plugged into mobo header and has the yellow wire. Tried loadsa different fans, same problem. Is there a setting in speedfan? or do i need mobo updates?
Suggest you do some more research
