Hi,
After finally sorting out my terrible wiring (see here) I got back to OC'ing my setup. I've put CPU up to almost 3Ghz and memory to 1000Mhz at 5-5-5-15
Edit: Orthos RAM test didn't like 1000Mhz, back to 834 for now
Orthos has now been running over 30mins and all temps are about the same as the pic except Speedfan Temp 2: 58C
What is this temp, northbridge? And is it safe? I ask because it's much higher than before the OC. Was about 45C.
Could be due to me putting up voltages. I upped FSB voltage, MCH voltage, DDR2 and CPU voltages. All up just one notch from stock in BIOS
