26 Mar 2008 at 16:55 #1 DAnDan DAnDan Soldato Joined 22 Feb 2008 Posts 4,473 I'm just checking some temps with speedfan, but I'm confused as to what some of them are, Temp1, Temp2, and Temp3, what are they?
26 Mar 2008 at 17:13 #2 naudiz naudiz Associate Joined 24 Apr 2007 Posts 545 Location Rochford Temp 3 looks like its bugged, maybe the sensor doesn't work or is unplugged, 1 and 2 will be maybe a northbridge sensor, maybe general mobo sensors Naud
26 Mar 2008 at 17:16 #3 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Compair them with Mobos's Bios, disable weird ones (they are simply unused) and rename them to like. CPU Mobo HDD If recent Mobo, advise you use the latest 4.34 Beta (final is due any time) cause it adds support for many newer Mobo's Last edited: 26 Mar 2008
26 Mar 2008 at 17:19 #4 DAnDan DAnDan Soldato OP Joined 22 Feb 2008 Posts 4,473 It's the Gigabyte GA-P35-DS3L board. Will take a look in the bios now, thanks.
29 Mar 2008 at 10:10 #5 postmanfw postmanfw Soldato Joined 7 May 2006 Posts 3,191 Location Fort William You can get a custom config for your motherboard if you sign up at site http://www.almico.com/sfhandleconfig.php
