SpeedFan temp readouts.
29 Apr 2007
Teesside Uni
Hey, someone able to say which temps are which? Last two are CPU Cores and top is CPU overall? and HD is my harddrive, but the others?
Cheers
Compare with your bios, and stop fans with hand if needed to get rise in temps to make sure you got the CPU one if bios temps are close to mutli ones in Speedfan, it reads my Asus wrong but I can get real CPU/MOBO/HDD temps by bit of working out and now I keep a copy of the .ini for reinstalls as I have renames all settings so its nice looking.
I thought as standard temp1 was motherboard sensor and temp2 was the outer part of the CPU (ie. not inside the chip).
