Speedfan Temps
  • Thread starter Thread starter 4p
  • Start date Start date
4p
4p
20 Jun 2006
Capital of The North
Which is which??
I believe Core is the cpu core? 24c is a nice temp i think(overclock?)
HD0 is oviously the HDD
So what is Temp1, Temp2, Temp3
And Temp1 again??
Thorpy said:
Which is which??
And Temp1 again??
I'm not sure, but regarding CPU temps dont go off speedfan. use CoreTemp or Intels TAT as speed fan may be out by 10C-12C
Click configure in speedfan, top right corner ish.
This will tell you what sensor is in use and you can find out from there.
Just used CoreTemp
Its around 28C with the stock cooler
Windsor core - im told these aint the best overclockers
