Hi, lately I have been trying to make my old laptop a bit faster...
I have ran partition magic on it and changed the sizes (The 60 GB HDD was split 30:30) Doing this made it a little faster but nothing really noticeable
I wanted to clean up windows as my friend has a net top PC with a close spec but it runs a lot faster, this is because there isn't much information. I found that pc only had 20 gb used while I only have 8 gb left on the now 42 gb partiton, with windows taking up nearly all of it
Would it be just easier to reinstall windows?
It is running Fat32 and to change I would have to get a different install disk, could you have 2 partitions with different file systems? but I though if I would do that, then I would just get rid of the second partion
