- 29 Dec 2007
- London
Hey guys,
A few questions I need help with
We're doing a full backup everyday of around 230GB-290GB. The majority of this is taken up by a 180GB .bak file + a few other fairly large .baks and a large collection of small files and folders.
Currently the backup server (connect to the tape/RDX) is a Dell PE 1850 (dual core 3.0 xeon + 4GB) and the source (where the.baks are stored) is a Dell PowerVault 220s with a bunch of 10k drives connected via SCSI to a PE 2850 (2 x dual core + 12GB). All the machines have 2 x 10k drives in for the OS
(the servers are getting upgraded in ~6months)
All servers are connected with 1gb connections.
We were running a Exabyte Storage Loader VXA-320, unfortunately our main unit and our backup unit have now failed
we were due an upgrade anyway!
We've just bought and "installed" a Tandberg RDX QuickStor USB3.0 External caddy and 10 x 500GB cartridges. Our server only has USB 2.0 ports.
Unfortunately we're having some speed issues.
The old tape loader was doing around 510MB/min, totalling around 9-10 hours
We tested a normal Iomega 1TB USB 2.0 external hard drive which did 256GB in a shade under 7 hours at 622MB/min
The last two nights we've run the RDX it's been going at 300MB/min taking pretty much 15 hours
We're using Arcserve Backup R16 and running with no compression.
As test I've been running a backup during the day with compression enabled and so far we're getting ~460MB/min.
Summary:
Tape: 510MB/Min
USB 2.0 drive: 620MB/min
RDX no compression: 300MB/min
RDX compression: 460MB/min (currently 180GB into 40GB)
Any options to speed this up? I assume the RDX cartridges are 5400rpm. Will switching the internal disks to 7200rpm drives help matters? Possibly switch them to SSD's?
Add in a pci-e usb 3.0 card?
Our DB admin deals with compression on the .bak files, will this be an area where things can be speeded up?
Any idea's where the bottleneck will be?
Summary:
Tape: 510MB/Min
