Hi,
I'm setting up a small network for 3d animation and compositing, and need a bit of advice as to the best way to go about setting it up.
I will have one server and two workstations for the time being, and will set up raid on the server (prob raid 0 with an external backup running nightly).
At the moment I have a basic netgear 5 port gigiabit router connecting the 3 machines with cat-6 cable, all 3 run xp32. Transferring files over the network is pretty slow though - a 100 Mb quicktime takes roughly 15 seconds to go across, compared to under a second between different hard drives on the server.
I only have them set up by sharing folders and mapping network drives, so is there a better and faster way to network them together? Should I be looking at windows server 2008? Will upgrading all 3 to windows 7 pro 64 improve the situation at all?
thanks for any advice,
matt
matt
