Why not just go by your speedo, it's under reading and you will be fine. Why bother pushing it the odd mile an hour the GPS will give you to save all of 5 minutes.
my speedo matches my gps perfectly on my FiestaST, 130 is 130.
my speedo matches my gps perfectly on my FiestaST, 130 is 130. On my Fiesta 1.2 the speedo was well out.... 110mph was about 89![]()
Seems rich from someone who stuffed their BMW in a ditch showing off at a meet.[TW]Fox;18402514 said:130mph in a Ford Fiesta
No wonder they cant trust people enough to increase the motorway speed limit.
I'd set the cruise to 75 the whole way. The roadworks around Nottingham finished months agoWhich do you trust? I'm driving up north soon and when my speedo says i'm doing 70, my sat nav says 65. Don't wanna get stung by the SPECS near nottingham on the M1.
Which is to be trusted?
I'd set the cruise to 75 the whole way. The roadworks around Nottingham finished months ago![]()
What the hell is this supposed to mean?[TW]Fox;18402514 said:130mph in a Ford Fiesta
They have kept the specs at 50 though. What I heard.
Clearly the car is safe to drive at this speed, seeing as it's the vmax.
That's irrelevant. If the Fiesta was unsafe to drive at those speeds then it would have been limited from the factory and that's a fact.In some respects, you could argue you'd be safer in something bigger than a Fiesta, Compare 130 MPH in a Fiesta to a 5 Series for example.
That said, crash @ 130MPH and it'll probably matter little what you were driving....
