Speedstep & CPU-Z
7 Feb 2008
Good morning all!
I think im having issues with speedstep, I need it to be off because of issues with Cubase. So I've been in to bios and turned it off but when I look in CPU-Z the cpup seems to be swtiching between 6x & 9x mulitplier. It seems to do it quite a lot in fact. Does this sound like either speed step is still on or their might be another problem??
Thanks for your help in advanced!!! :)
Are you using Vista, check your power options and tick high performance.
In your BIOS there might be couple of options you may need to disable (C1E & EIST)
Rob
