Speedtouch 330 port forwarding
18 Aug 2004
The Toilet
my mates got one of these on tiscali, its connected through USB, hes in air force barracks so i cant really go around and have a look to see whats up with it, dont really have a clue howto configure but its not letting us play pro evo together :(
Anyone fancy dropping a link to an online guide to port forwarding on it or something? Cant even find port forwarding in the online manual for it..
Unless I'm thinking of something else isn't the 330 just a very basic USB modem?
If so then there's no ports to forward and it's probably a software based firewall causing any problems he has.
Correct, the 330 is just a adsl modem so nothing would be blocking the connection, probably his antivirus/firewall blocking it.
As stated above, the 330 Frog has no firewall or NAT at all - if ports are being blocked they will be in Windows Firewall or ZoneAlarm or similar on the PC.
Do you have to setup a server in pro evo? If so and its you thats setting it up, you will need to do the port forwarding if you have a router.
