Speedtouch 586 v6 – 6.2 firmware.
26 Feb 2004
Hampshire, England.
Hey guys,
I’ve just noticed that there is a new firmware out for the Speedtouch 585? Well it’s new to me; I’m currently using 6.1 I think?
Has anyone got anything to say about it, positive or negative :)
Also, if I do decide to upgrade can anyone remind me how you do it on this router; I think the upgrade is a .bin.
Cheers,
SW.
So no ones using the 6.2 then?
I'm currently using my Netgear so I've got the opportunity to try it out if someone’s going to be kind enough to remind me how you update the firmware on a Speedtouch :p
Cheers,
SW.
Im using 6.2.17.5. No problems here either. Had to re-configure it to work with Be though, but that isnt hard. :)
