Speedtoutch & other routers DMT Tool tweak guide
A quick guide to tweak your speedtouch or another router for that matter, (although you will have to download a different DMT tool version but the principal is the same)
1: Download and install DMT Tool version v7.31, Extract the DMT file and drag onto desktop, (No install needed)
2: Run the program and Select English.
3: The program will look like this below:
4: In the connection establishment box you need to enter the routers username & password, mine is the set as default so my username is Administrator and no password,
5: Hit connect and it should receive data from the router which will look like the following
6: This is now tweak time
Select special on the menu bar then Misc. Options, then click the box which say 'unlock experimental area' and hit yes, then save and close, There will be 3 new tabs next to Info 1 2 & 3 this is called modemoptions,
just let me know and ill add/update it.
