Spend my £500 for me!
16 Jun 2009
need to update my archaic pc. I have £500 to spend, ive already got 32Gigs of DDR4 ram(corsair vengeance lpx) and a small NVMe drive to put the OS on. I have an NVidia GForce 2060 Super which tbh runs things fine at the moment in 1080p so i will keep that and upgrade it in a few months time when i can save some more money. Appreciate that it will be a bottleneck now but thats ok. I really just want a MB and CPU. Was looking at a Ryzen 5 5600 but think i can push the boat out a little more with a bigger budget if its worth it. I just dont know much about motherboards.
What say ye?
seeing as you need a mobo as well, I'd be tempted to sell the 32gb of ddr4 ram and just go am5. £500 is more than enough for a mobo, 7600x, 32gb ddr5 6000c30 and a cooler
below is 50 game average of the 7600x vs the 5800x3d..at 1080p the 5800x3d is 4% slower than the 7600x, and that's faster than the 5700x3d. Also with the am5, you've got a future upgrade path..if buying a am4 mobo and then the 5700x3d, you're basically done..nothing to upgrade to in the futre without getting another mobo
selling the ddr4 ram gives you a bit more cash to either put with the £20 left to go towards your future gpu upgrade down the line or get a better mobo(though nothing wrong with the eagle, can run a 7950x so wont have a problem running a 7800x3d/9800x3d in the future etc
My basket at OcUK:
Total: £479.95 (includes delivery: £0.00)​
I think in long term investment terms the above AM5 advice is sound, might be a bit overkill for your 2060 right now, but its gives you plently or options going forward. If you shop around you can get the same or similar above for around £40 less, which would leave you budget for a 1tb nvme (as you mention above the one you have is small).
