spider macro (i want closer!!)
30 Aug 2003
i would love to be able to get better clearer shots of insects from macro like from the thread made by "famas" , but cant get any closer than my pics below, what would i need to get to be able to use the lenses i have now? or is it a no go with what i have?
i have the Sony a 200 with 18-70mm sony lens, and also the sigma 70-300mm APO lens, which has a macro mode, that will get me 2:1
thanks
reversing threads are dirt cheap off the bay.
I bought a 52mm-52mm one for about £5. I mount my 50mm prime (which needs to fully open otherwise you'll see a dark ring round your pictures) on the end of a FD sigma 28mm macro with a x3 TC.
I have no idea what the mag ratio is on that but it's pretty damm close!!!
The above where taken with my setup (sadly I have no flash so I had to use a wide aperture just to get enough light in hence the shallow DoF).
Hope it helps. :)
Yes. You divide the focal length of the lens on the camera by the focal length of the reversed lens to get the magnification. So a 105mm and a 50mm will give 2x magnification; a 105mm and a 35mm will give 3x.
Ok, I fancy having a play with a reversing ring now lol. Which lenses should I use for the best result? I have:
canon 17-55mm F2.8 (78mm thread)
canon 18-55mm (kit) (58mm thread)
canon 50mm (52mm thread)
canon 28-135mm (72mm thread)
canon 60mm macro (52mm thread)
sigma 150mm macro (72mm thread)
Would any combination result in a better result than the sigma macro? I still don't understand the maximum magnification value for lenses. Surely a 300mm lens has a greater magnification than a 150mm lens?
Forget about the zoom lenses. The usable combinations are 150mm with 50mm or 60mm on the front. This will give you 3:1 magnification as opposed to the Sigma's native 1:1.
Only when focussed at the same distance. A macro lens is designed to focus to very short distances which a standard telephoto lens isn't. For example, a 150mm lens will give 1:1 magnification when focussed to 150mm (this is a simplification for the sake of illustration so anyone who knows better please keep quiet) and a 300mm lens will give 1:1 when focussed at 300mm but most 300mm lenses probably can't focus closer than 1 metre so will only give 1:3 magnification. I hope this makes some sort of sense.
i appreciate that, but the cost is a limitation, unless you can point me in the direction of some good priced 1:1 macro lenses
For Sony cameras I don't know, for Nikon or Canon just go to a 2nd hand camera shop and there will be loads of cheap macros (55/60,105mm 2.8 lenses).
For Sony cameras you might have to buy new.
Cheers for help. Just ordered a 72mm to 52mm reversing ring. Will post once I try it (coming from Hong Kong!).
There should be a good number of s/h Minolta lenses around.
I guess it depends on the location and the shop. I go almost weekly to a 2nd hand camera shop to look for bargains. Always loads of Nikons and Canons, a fair few Tamron/sigma in Cannon and Nikon mount, and some Lecia, Zeiss, and medium format stuff. I've only ever seen 1 or 2 Sony or minolta lenses or bodies. The other camera shops I occasionally glance at are similar. Pentax and olympus is much the same.
Maybe in Switzerland everyone shoots Nikon/Canon. Maybe Monolta/Sony/Pentax users take their glass to special shops (which I have never seen and certainly aren't in my home town).
(this is why I don't see the appeal of other camera systems, personally for me I just could not physically buy 2nd hand glass for love or money from an actual shop)
Yesterday when I looked you could pick up a perfectly good working 55mm Canon Macro or 60mm Nikon for 50-60 quid. The AF-S/AF-D version being more but manual focus for macro work is no big deal.
got a sigma Achromatic macro lens from Snapshot, and here is the result (cheers)
i need to use my tripod, this was hand held
the pic of i don't know what type of fly on a strawberry flower
