Splinter Cell Chaos Theory Controlls :(
1 Dec 2006
Amsterdam, NL
I installed this the other day and am still getting used the the controlls...
1) It doesnt recognise the 2 triggers on the 360 so thats annoying
2) The layout on the 360 pad is very odd.....
3) I would LOVE to use keyboard but seeing as going foward is a key not a stick, there is either fast moving or not moving lol. so pointless when im trying to play stealth.
Anyone had these niggles and solved them?
love this game and would like to play it properly
ags
You do realise the mouse wheel controls your speed don't you?
Quite annoying playing Splinter Cell Chaos Theory or Double Agent until you work this out. :D
Couldn't for the life of me crack a safe in Double Agent until I checked on here for threads and realised what I had done. :o
Your kidding right? The mouse wheel controls your movement speed?...
Ive just been playing the first mission with the controller, think i have got used to the controlls now anyway :(
Its a brilliant game :D
ags
I loved the control that the mouse wheel gave to speed, so precise - one of the best control options ever IMO.
been playing with the 360 pad, bit of tinkering with the layout and it's perfectly fine, is a bit crap that it doesnt see the analog buttons, but i've had no problem, love this game :)
You'd be silly to play the game with a 360 pad, when a keyboard and mouse (with scroll wheel) works perfectly.
Then I sir, am extremly silly, just can't play SC with keyboard and mouse, doesn't feel right to me. I think it's perfectly suited to a joypad.
