i just bought and installed splinter cell- double agent but every time i try to run it it crashes displaying a box that says-trying to set non registered vertex shader. i ran the hardware detection that came with the game and it said that my system meets the minimum specs to run the game , except for a big red cross next to-shader model 2,000000. then it says it needs shader model 3.0 or higher.
is there anything i can do about this or would i need to get a better grfx card to run this game? i hope not as i`m a bit skint at the moment, but if this is the only solution could someone suggest a card that would run it,to replace my current card-ATI radeon 9800xt? preferably one that wouldn`t cost to much.
thanks in advance
thanks in advance
