SplinterCell Double Conviction PC
2 Oct 2004
N.W London
Hi Peeps,
I installed the game on my E drive and now half way through am enjoying the game...
Trouble is after I die and select try again the game crashes, this has never happened before.
My system can easily handle this game - see my sign...
It has never done this before, so whats happening?
Should I try reinstalling it?
Please advise
Thanks
sorry yes double agent...
so i just reinstalled it and its so frustating because when I die and it tries to reload the game crashes and I go back to windows...
whats up with it?
If it's only happening while restoring one save then its proabbly a save game corruption. Try loading a different save.
Is the game fully patched? I remember playing this through without too many problems.
M.
Yeah make sure the game is fully patched and try loading a different savegame.
I had a similar problem with FarCry2. Whenever i used certain medkit boxes it would crash. A patch sorted it out.
where would I get a patch from?
I have tried a few different saved games all on the same level and it happens to em all...
any further ideas?
Meanwhile I will try a previous level to erradicate the possibility of it being only on this level as all previous levels have been fine...
