Hi,
I bought a 12,000 BTU split air con. unit for a small bedroom with no windows or heat sources, it has two pipes, in the manual, it says connect the pipes, evacuate the air by letting a little gas out (done!). Now the air is evacuated, as instructed, the valves are fully open, I have checked for leaks. and everything checks out. However, although it is a little cool, it is not very cool and where the indoor unit pipes are, the pipes have huge blocks of ice around them even with insulation, what do you think could be the matter? My supplier reckons I've let all the gas out of the outdoor unit and says I will need to get someone out to recharge it, but I think this is carp coz there is defo no leaks, and it is cooling, but not much?
