- 2 Feb 2010
- Crowmarsh
Front left tire was very low on air today, checked and it was down to 13psi. Closer inspection of the tire revealed a small split in the wall near the wheel rim
there's a reasonable amount of tread on the fronts too. Will I need to replace both fronts? Car is a z4 with 18 inch wheels if that makes any difference. Guessing I need a new pair of fronts
. The guy cleaned up the corroded area so I shouldn't lose any air now (Until the corrosion worsens), so it's all good for now. Will be getting the wheels refurbed in the summer.
