split intercooler pipe
30 Jun 2008
i have mondeo st tdci and i noticed lacking power and black oil underneath
opened bonnet and the pipe that goes from theinter cooler to that metal cylinder thing on the engine has a split in it
is it ok to drive it if i take it easy?
Its not a problem in the same class as a leak in a coolant pipe.
Your engine will be overfuelling, as there will be less air going to your cylinders than the MAF is reading. However I dont think that will be a big issue on a diesel.
Superglue works well on rubber as a temporary fix.
