Anyone know of a 1 (in) 6 (out) molex splitter box, I could have sworn I saw one on the net somewhere but can't remember where.
OR 1 in 6 out molex splitter cable.
Fractal Design used to do a PCI-mounted Fan Power Splitter, which had a load of male Molexes (Molecies?) on it and 3-pin fan headers, but I think they all had different voltages.
Seen a couple of other designs, but nothing to buy, that I recall.
I was thinking about making one up if there wasn't one available to buy, but not quite sure about how many molex plugs/sockets I can run off one connection.
I'll have to do a bit of research methinks.
I have a single lead with 3 connectors off the PSU. Each connector has two 12V accessories bridged off it. That makes six 12V thingies running off one lead on an OCZ 650W PSU, as well as all the other usual gubbins and I haven't had a single problem yet... Not really very scientific, I know, but it's a start!
Nah, nothing so fancy.
Half of them are LED light strips that came with the bridges pre-wired.
The other half are basic "5¼ inch power supply" splitters from 'a well known high-street electronic component retailer' plugged into various things.
The main cable is just a standard 3-plug Molex type that comes with every PSU.
