Splitting audio to two devices at once
27 Feb 2020
Hey all,
Recently built my gaming PC for use in my living room, I had it hooked up to my TV & a Headset for gaming.
What's the best way of splitting audio to the TV & Soundbar via HDMI and Headset via USB ( It's an Arctis Wireless Pro with the AMP )?
I've tried Stereo mix and get no sound, not sure if there is something I am missing even following guides. I've also tried Voicemeeter which works but there seems to be a slight delay between both devices & lower audio quality.
Any ideas would be appreciated!
Thanks
You want sound from both at the same time? Windows 10 has the ability to switch via the task bar icon but not both at the same time.
Yep same time, you can do it with Voicemeeter and some people think you can do it with Stereo mix but I've had no luck with the latter.
As mentioned Voicemeeter works but there is a delay and a drop in audio quality slightly.
