@ SickAsParrot - thanks for that. I have had a look at the Magix (Audio Cleaning Lab) and find the three offerings ("Audio Cleaning Lab", "Rescue your Vinyl & Tapes" and "Audio & Music Lab" confusing and the website doesn't help much on initial inspection.
Looking at the "Rain forest" reviews I get the impression that the latest version of the basic software has had features removed from the earlier version - e.g. Spectral Cleaning. Presumably this is to encourage upgrades to the "Premium" version? The software looks to be pretty sophisticated - i.e. it can easily get rid of some of the inevitable surface noise. I will try to research it some more. I presume it doesn't require the initial use of Audacity?
@neil_g - thanks to you as well. MP3split looks to be well worth playing about with - and is FREE!
May I ask what you used to record them in the first place? I have loads of Albums, 12" and 7" singles that I want to convert to a digital format but have no idea how to do it.
I play LPs on a Technics SL-1012 Mk. II turntable and and feed the signal into a Sony TA-FE330R Amp.
I use a three metre lead that has a red and a white Phono plug at one end which is plugged into the Tape 1 output sockets on the rear of the Amp and a single three-way 3.5mm phono plug at the other end which is plugged into the "Blue" (input) plug on the back of the PC.
I am 100% sure that there are better ways including using a £20 RIAA pre-amp between the turntable and the PC. However, I use what I have and this approach would also allow me to record / convert radio and cassette tapes.
The software I use to convert the analogue audio into digital format is Audacity v2.0.6 (
http://audacity.sourceforge.net) with the LAME for Audacity MP3 plugin, both of which are free downloads.
- To start recording, click the "Red circle" (Record) button.
- To stop recording, click the "Yellow square" (Stop) button.
- To export the file, select File -> Export Audio
- Trim the lead-in and lead-out if you wish.
- Choose "Save as type" MP3 files
- Give the file a name
- Click "Save".
NB1 - this process is not quick, it is not like ripping a CD in a matter of minutes using something like Exact Audio Copy, you have to play the entire LP.
NB2 - make sure that your PC doesn't make any other unexpected noises while recording otherwise these will be mixed into your recording - so no YouTube to while away the hours and no plugging / unplugging USB memory sticks!
NB3 - you will record everything output by your turntables including the obligatory snaps and crackles - you will have to use some other software to remove these - see posts above with which I have no experience as yet.
