Splitting one VGA input to two outputs
25 Jul 2004
I need to split a VGA output signal from a PC to a TV and data projector. I have found a product which will split the signal and show it on both screens simultaneously, but I only want the picture to shown on one or the other at any given time.
Can anyone suggest a suitable product?
Many thanks
VGA switch box with a manual button is the best bet, but don't think they are that common anymore. Only other thing you can do is have a dual display graphics and then use the computer to turn the displays on and off
