Splitting Phone/ADSL.
26 Feb 2004
Hampshire, England.
Hey guys,
Presumably when the 2 BT wires enter our homes they are carrying both ADSL and Phone signals :rolleyes:
Now, following a suggestion from a former BT engineer :-
If my master socket does not incorporate a built-in ADSL filter is it possible to split the output myself?
If I were to say add two more wires (Currently unused Orange/White and White/Orange) to points A and B on the master socket and joined them through the rest of the houses extension wiring (About 15m) and terminated them at a BT NTE5 faceplate with an ADSL filter built-in, would I have a reasonably well filtered line, free of all interference from phone devices etc…
I know it sounds a bit long winded and I’m not sure if it would even work, but if it did there would be no need to additional microfilters around the rest of the house would there? And I would also have a totally dedicated ADSL line going to my room :D
Maybe improving my stats a little bit too :)
Please could someone put me straight?
Cheers,
SW.
In theory that should work except you'd need a filter at the master socket if there is a phone or anything else plugged into it. Also bear in mind that tampering with the cabling behind the master socket is illegal.
You're better off just getting one of the NTE5 faceplates for the master socket that also has terminals for unfiltered extensions.
