Again like my other post this is probably very simple as im not exactly a genius when it comes to coding. Here is the scenario:
I have a text file with a name and number for a series of students. The file looks like this:
I want to insert this file into a database so it looks like the following
Student Number Student Name
0756363 Paul Smith
046252 Dave Smith
I used the string split function to split the string every time it sees a comma. This works fine.
What I need to do is loop through the array of split strings and insert the number and the name into my table until the file is read. I figured this would be pretty simple. However this is the closest I have got:
0756363 0756363
Paul Smith Paul Smith
046252 046252
Dave Smith Dave Smith
If I use one variable such as the student number i can get all the student numbers in the file into their proper table but as soon as I try the name as well it all kicks off. I know this will be a simple error but if anyone can give me an idea i'd be most pleased. The method i've wrote to do this is below:
Thanks for your time
Code:
0756363,Paul Smith,046252,Dave Smith
0756363 Paul Smith
046252 Dave Smith
0756363 0756363
046252 046252
Code:
Sub readText(s As Object, E As Eventargs)
objConn.Open()
objStreamReader = File.OpenText("C:\Temp\names.txt")
Dim strInput as String
strInput = objStreamReader.ReadToEnd()
Dim textDelimiter As String
textDelimiter = ","
Dim splitout = Split(strInput, textdelimiter)
lblplaintext.text = strInput
Dim i As Integer
for i=0 to Ubound(splitout)
'For testing purposes
lblsplittext.Text &= "<b>Split </b>" & i+1 & ") " & splitout(i)& ""
objCmd = New OleDbCommand("INSERT INTO NAME (studentNumber, name) VALUES (@studentNumber, @name)", objConn)
objCmd.Parameters.Add("@studentNumber", splitout(i))
objCmd.Parameters.Add("@Name", splitout(i))
objCmd.ExecuteNonQuery()
Next
objStreamReader.Close()
objConn.Close()
End Sub
