SpotCool - Which way?
set it to blow onto the target components. low fan setting is practically silent, and should do you nicely, depending on your needs.
i have one on my ram, another on my northbridge, they keep my abit ip35 pro (toasty pwm) happy when stressing.
Cheers, it's blowing on to Graphics card/RAM but the card still overheats (ruins game play with them annoying graphic errors) that's why I assumed it may be rebounding the hot air from the card.
Great but the problem is the card displays graphics wrong when hot (7600GS). I might just get a new better card as well -.-
