KadreMoD said:3 cans of primer
3 cans of paint
2 cans of laquer
That's what id suggest anyway. a 300ml can of spray(Halfords car spray paint) paint only just covered one of my side panels. So I think 3/3/2 would be ok , seeing as your painting the outside so it will allow for a mistake or two.
I always like being on the safe side. Nothing worse then using up 2 cans of paint and realising there a big scuff or you've found a fingerprint in the paint.
. Plus you should get a good sense of achievement when it all comes together.
Mark A said:Sounds like a good idea, ive got to admit vinyl does look great. Is it easy to remove though if you plan to paint at a later stage?.
fixedmessiah khan said:You can't use vinyl! Every time someone uses vinyl, RBCUSTOMS kills a domo-kun. Think of the domo-kun!!![]()
messiah khan said:You can't use vinyl! Every time someone uses vinyl, RBCUSTOMS kills a kitten. Think of the kittens!![]()
