pretty much what you need here: primer, black gloss - the green (for flames).
its from a mod project on custom pc - the featured one. never dpne any painting my self.
I've used both plastikote and Holts and imo holts is much better. It comes out in a much wider spray which is a lot better for getting the thin coats you need. Plastikote also has an annoying tendency to wrinkle if you put a little too much on though that could have been my noobishness.
