You may of gathered from my other posts that I generally have a go at most things car related.
The wing I replaced on the Rover got damaged when the drive way wall suddenly clipped me![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
So I have taken the wing off.
Gave it a good clean. Managed to knock the dent out within about 10mins of careful work with a piece of wood and hammer.
I have sanded the dented area down to bare metal or almost there to get the scrape marks out.
I had some primer in the garage so I have primed this area, just waiting for the first coat to dry.
I will give it a quick sand then do another primer layer.
My question is though is where do I get perfect match paint?
Should I just get a can from Halfords shelf? The car is white so it shouldn't look too bad if it's not 100% perfect.
Also how many coloured coats? 3?
Do I need to laquer after?
Cheers,
Chris
Cheers,
Chris
