Spraypaint Case?
10 Jan 2007
I have an aluminium beige case. I'd like to make it black.
Will spraypaint stick, do I need a special type? Also, would a regular black spraypaint match the colour of black bezel optical drives?
if you use gloss they will look out of place, try a satin or a matt finsih spray paint, plastikote/cote from B&Q or homebase is your best bet!
make sure to sand the case before painting it. im not sure if a undercoat/primer is necessary if you sand before hand. ask 'R B Customs' on here whast the best way to go about doing it.
