Spring clip for 30mm fan on heatsink???
Permabanned
30 Dec 2021
Yorkshire
It is possible to get a 30mm clip for mounting a phanteks d30 to a heatsink
The stock clips for the standard 25mm fans won’t stretch the extra 5mm
Yep I literally just did that. With the fan been 30mm it holds itself inside the towers. So I used a 3mm zip tie to just clamp the tower tops together. It’s looks ok
Haha yes! The stock clips work on the edge fan
lol £30 cooler £50’s worth of fans haha
