springy screws as you call them
are usually so you cant over tighten them
so basically when they bottom out theres a set amount of pressure
Hey you're not unlucky anymoreShould point out that they generally come coupled with a screw that bottoms out so it can't be tightened as such. It's just "all the way in" and can't go in further.
Why do air coolers come with springy screws for mounting to the brackets / standoffs? Why not just normal screws?
Daft question but I’m genuinely curious.
Hadn't noticed, thanksHey you're not unlucky anymore
Hope that's a good sign![]()
