Hey guys. Recently just got my bike serviced and MOT'd and all was dandy!.. Until 100 miles later.
Was on my way home the other day and got some horrible crunch, clanky like noises and almost felt like I had a flat tyre when going round corners. Sounded like it was coming from my sprockets/chain.
I was told that my chain had a tight spot (but would nothing serious), so got off and checked it to see if they had adjusted it funny, seemed a little on the slack side but nothing too serious.
Anyway, got home done some adjustments to my chain but alas, still the horrible noises. So I decided to pull the rear wheel off. I've never had a bearing go so don't really know what i'm looking at but the bearing on the sprocket seems to have some play, if i stick my finger in the center i'm able to jiggle that part around, easily.
Is this likely the culprit?
Cheers in advance for any suggestions!
