Spybot with a USB stick
19 Jan 2005
Romford, Essex
Can I run Spybot Search & Destroy from a USB stick. I currently run it on my PC but still find it has slowed down IE8 even with no immunization.
I would like to check my Netbook for Spyware but am loathe to install Spybot. If I can run it occasionally from a USB stick I would consider doing the same on my PC too.
Can it be done? Thanks
MalwareBytes would be my personal reccomendation mate, I'm a big big fan of SpyBot but after tests in work we found MalwareBytes to be more effective.
spybot can be run from a usb stick as i have it on one just incase
as far as i'm aware malwarebytes can't be though :(
Thanks for the replies.
Can you ell me how to install it on a USB stick as I am having some difficulties.
First I downloaded the file and installed it onto the stick, but it corrupted the installation I already had on my PC.
I have now uninstalled S&D on my PC and tried again to install it on the stick but it still wants to install certain files to my PC C: drive as well as start up icons which I unticked.
Any advice please. Do I need to make a new installation on my PC and copy the whole directory tyo my stick or do certain files get copied to a windows directory. Thanks again for some help
