12 Nov 2015 at 22:42 #1 sid-180 sid-180 Associate Joined 6 Nov 2009 Posts 551 I need to calibrate my new macbook pro with the spyder pro utility so need to know the correct settings. anyone know the exact settings for the macbook pro?
13 Nov 2015 at 09:24 #2 postbox postbox Associate Joined 14 Mar 2012 Posts 793 Unless I'm reading this wrong, does the Spyder not find the correct settings for you?
13 Nov 2015 at 10:02 #3 Cosimo Cosimo Man of Honour Joined 9 Jan 2007 Posts 164,704 Location Metropolis Try this: http://www.damiensymonds.com.au/cal_S4P_mac.html Just search for 'spider macbook pro calibration'.
13 Nov 2015 at 17:22 #4 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 Cosimo said: Try this: http://www.damiensymonds.com.au/cal_S4P_mac.html Just search for 'spider macbook pro calibration'. Click to expand... Thank you
13 Nov 2015 at 17:22 #5 sid-180 sid-180 Associate OP Joined 6 Nov 2009 Posts 551 postbox said: Unless I'm reading this wrong, does the Spyder not find the correct settings for you? Click to expand... I know on windows it tends to ask you for additional bits so wasn't sure about the Mac
