. I use Spybot S&D for it's immunization feature and a weekly scan, I don't use Spybots realtime features. I use Malwarebytes only when I have/suspect spyware is on the machine. I haven't had to use Malwarebytes yet
.You can use them both...
Isn't Malwarebytes 32-bit only?You can use them both to run weekly scans or something, much better than relying on just one
Superantispyware is the only one that fixed a recent issue I had, Adaware and Spybot failed, although still I have Spybot's TeaTimer app running.I use them both and then if still problems superantispyware.
not a fan of adaware these days.
Hi all,
Which one of these apps do you rate higher?
SPYBOT Search & Destroy or Malwarebytes - Anti malware
Thanks
Anybody like SpySweeper?
I've been told it's one of the best! - lol
