Spyware/rootkit problem
6 Sep 2008
Near Hull
a lot of sites I go on I keep getting a file trying to download itself:
bk-coretag.js from tags.bkrtx.com
dpx.js from i.simpli.fi
Both of the above, it's not just one certain site it seems to be nearly any site I go on.
I've looked online and found how to remove them using malwarebytes and it says they're gone but they keep coming back and my avast keeps going crazy.
there's also a file in my C drive which wont delete and the bits I delete keep coming back - program file\MSR\privoxy. which is causing avast to go crazy and can't get rid.
anyone got any help for these problems? getting really annoying now.
Try downloading the Kaspersky rescue disc, burn it to a CD or copy to a bootable USB. Then let it update and run a full scan, then reboot and clean temp internet files and the temp folder under Windows and User.
