when i add a table entry in sql with a "-" it comes out with a [] around the item
Note: im using an "_" (underscore) as well in the entries if that makes any difference
for example
test_example-1
then becomes
[test_example-1]
anyway to get past the "[ ]" ???
for example
test_example-1
then becomes
[test_example-1]
